HELP - blue monstrosity refuses to cooperate with me and i am losing my mind
Old Oct 5, 2020 | 06:12 AM
  #21
Extinct's Avatar
One last test for the exhaust leaks is to shove a leaf blower/shop vacu up the tail pipe and use windex at the manifold connections, if there leaks there will be bubbles. Do it cold of course. With an 03 a cheap mechanical pressure gauge can be installed in the oil cooler port on the filter housing. Get an aluminum plug the same thread size at the auto parts store and drilll and tap for the fitting.
Old Oct 5, 2020 | 07:06 AM
  #22
keninnc's Avatar
If the ticking begins at start up and not when the engine temps get to 100 degrees or so then there may be hope it's not a slipped sleeve.
Old Oct 5, 2020 | 11:57 AM
  #23
Harvlr's Avatar
I've had several V8's that have had a worrisome ticking. So far, each time tightening the exhaust manifold bolts cured it, without needing new gaskets.
ReconDoc83
May 27, 2022 01:58 PM
user 789724o0
Sep 5, 2020 05:46 PM
ReconDoc83
Aug 29, 2020 09:59 AM
Sean Winter
Jul 9, 2020 08:06 PM
Jabez
May 16, 2013 06:17 AM
