DiscoII Key Fob Barcode
Old Jun 12, 2020 | 10:57 AM
Sean Winter's Avatar
Default DiscoII Key Fob Barcode
I asked a couple folks about this privately, but I'd like to get other opinions.
This is the key and code I got for my 2002 Disco. It is a 315mhz key, and my RF test on the Nanocom recognizes it and my original key. Problem is, I think the barcode is messed up? It shouldn't have two letters, NC? Maybe I'm wrong.
I get it synced, but not detected by the ECU.
Anyone in the US receive a code like this? It's from ebay seller.
Thx
Sean
USA
Old Jun 12, 2020 | 11:47 AM
acg's Avatar
acg
Nanocom uses the 6-digit code. The 6-digit code is usually stuck on the small circuit board inside the key fob casing.
Old Jun 12, 2020 | 11:51 AM
should have mentioned, no code inside the fob.
Old Jun 12, 2020 | 01:01 PM
cvhyatt's Avatar
Be careful with the ebay folks. Some of them say they are 315mhz but they are actually 433mhz. I have yet to find a new 315mhz on ebay. Most are used.
Old Jun 12, 2020 | 01:38 PM
I thought the RF Test would confirm it's 315mhz? But that would make sense if I can't get it to detect.
Sean
Old Jun 12, 2020 | 02:17 PM
cvhyatt's Avatar
I went through the same thing. I am willing to bet if you open it up and you'll see on the chip it says 433mhz.
Old Jul 8, 2020 | 08:27 PM
DodyDisco's Avatar
I pretty much ordered a cheap fob of every ebay vendor last week out of curiosity. All said 315mhz yet none would program using a nanocom.
They all shared the same generic non valeo inner board, no number inside on chip,although it seems the 6 digit number usually on the chip is also in the 1st barcode number. Guessing they are all actually 433mhz.
1 cheap fob yet to show up has the valeo board pictured so ill see what shows up whenever it does.
As of now i have a genuine new oem key on the way and the used guts from another, hoping they both program up no problem. 🙏
Pretty much think all aftermarket D2 keys on Ebay are basically a scam. Luckily returns were easy enough.
Old Jul 8, 2020 | 08:32 PM
Looking forward to the verdict!
Thanks
Sean
Old Jul 9, 2020 | 08:06 PM
DodyDisco's Avatar
Well 0 of 5 Ebay cheap key fobs would be detected when it came down to it on the Nanocom. Same experience with a locksmith buddy using the complete barcodes. So seems Ebay type cheap keys are a NoGo for 315Mhz Discos anyhow.
I must be a sucker for pain but wanted to try.
Still have 1 on the way that has not shown up yet was 30 Bucks and pictured a Valeo board.
​​Fob #6 above showed up. Completely different than the listing pictured. Same junk board the others had. Figured it would be but hey.
​​Mass ebay returns for me this week lol.
Used Genuine Valeo guts from a fob Synched right up and were detected 1st try.
nwilczyn
Sep 11, 2023 06:39 AM
eitydeuce
Jan 30, 2020 11:40 AM
Locksley
Range Rover L322 (3rd Gen)
Oct 20, 2018 05:02 PM
RedDrumJay
Jan 1, 2017 12:00 PM
tbdiscovery
Feb 16, 2016 04:35 PM
