Help bypassing the Ace Pump (temp)
Hey guys, im new here and hoping to get a little help from the experts, I just purchased my second discovery, its a beauty but the one problem is the ACE system is leaking pretty quick, im picking up the vehicule tomorow night and have to drive a few hundred kilometres, Ive been pocking around the site but could not find the answer. I need to temporarily bypass the ACE pump so I can get the vehicule home without causing damage to the engine, i was lucky enough to find a spare pump incase its busted, I have the 4.0 V8 and am wondering if I can just swap the belt to a shorter one to make it home or if I need some sort of pulley as well, any help would be much appreciated.
from the RAVE, which you need a copy of -
Dexron 11 or Dexron 111 non-synthetic fluid
Also, that belt was about double price at the dealer, most places that are big enough to sport a LR dealer have places like Auto Zone, etc., where it is maybe $34.
ACE fluid
Where ambient temperature falls below -20
° C (-4°
F), use only Texaco cold climate power assisted
steering fluid PSF 14315. Where ambient
temperature remains above -20
° C (-4° F), use either
Texaco cold climate power assisted steering fluid ,
