help!!!! can't figure out whats wrong
Old Oct 27, 2013 | 08:33 AM
sideshow's Avatar
Default help!!!! can't figure out whats wrong
I have a 2000 discovery ii, its been running rough, lack of power, exhaust smell around the engine. I had 2 codes misfire cylinder 5 and 8 I think. I replaced the wires, coil packs, plugs, and had the injectors cleaned. I have the same problem. any ideas?
Old Oct 27, 2013 | 10:11 AM
suzukisam967m's Avatar
Well it sounds like the possibility of a head gasket leak, assuming both symptoms you listed are relative to each other. You could have a vacuum leak and an exhaust leak at the flange. But assuming the two are from the same problem... I'd say head gasket. Can you hear a leak anywhere?
carmonalandrover
Mar 11, 2021 08:22 PM
rover newb
May 12, 2011 05:42 PM
jbm6287
Dec 10, 2010 08:33 PM
palabratic
Dec 5, 2009 07:52 PM
95DiscoSE7bullitt
Aug 22, 2007 05:59 PM
