Help, CD Magazine under passenger seat will not eject!
Old Apr 19, 2009 | 09:10 AM
Twistid's Avatar
Default Help, CD Magazine under passenger seat will not eject!
98-99 Land rover discovery 2, CD Changer will not eject magazine underneath passenger seat, fuses are ok... Any suggestions? Completly 100% stock, just stopped working one day =(
Old Apr 19, 2009 | 09:16 AM
Twistid's Avatar
When you change to CD it says "No magazine," When trying to eject it makes no noise or attempt to eject the magazine.
Old Apr 19, 2009 | 09:51 AM
Sound like your CD changer is toast or maybe came unplugged.
Old Apr 20, 2009 | 01:38 PM
salve7's Avatar
This may sound patronizing but are you sure you are pushing the eject button right? For the first two weeks I owned my rover I thought the CD changer was toast, however I discovered that I was pushing the button in instead of down or vice versa... Might be Im just slow but a thought none the less...
Old Apr 20, 2009 | 01:52 PM
NW_rockhound's Avatar
I'v had this problem too. I have just kept poking the button and pushing the mag around (maybe it gets stuck in there) and eventually it pops out.
Hope I didn't just jinx myself, but eventually it comes out.
Suppose you could unplug the CD player and plug it back in. I used to install the same Alpine CD changer in Volvo's in the early 90's, seems like there was a way to slide a business card under the cassette and unlatch it. I just don't remember exactly how.
Good Luck, David
Old Feb 18, 2012 | 10:42 PM
webdesign's Avatar
4wd High
+1 on NW_rockhound
I had, and still have the same "No Magazine" Issue. I came across this post, prior to being a member here and can say this technique worked and still works for me:
"I have just kept poking the button and pushing the mag around (maybe it gets stuck in there) and eventually it pops out"
Old Feb 19, 2012 | 10:14 AM
Big Jim Swade's Avatar
You probably shut the power off when it was changing discs. Raise the seat up and forward all the way, unplug the unit and remove the 4 nuts holding it in. Remove the top cover and check for a jammed CD. That's all I did with mine and it works fine now.
bfamous
Mar 17, 2014 04:16 PM
Rev Den
Feb 19, 2012 04:27 PM
harryhood41
Aug 10, 2011 11:21 PM
lisalisa
May 7, 2006 11:11 PM
