help with cdl install i have questions please!
hey guys,
i am installing a cdl in my 2003.... i have a complete 2000 disco cdl transfercase that i'm taking apart and i'm running into some problems
here is my progress,
why cant i remove the gear set in picture 3 i've been following the write up....shouldnt the gears just pull out
never mind i got it out when i removed all the switches from the main case that sense the high low arm... heres the pics did i do this right? did i get the right t case?
since i had the t-case out of the truck i didnt remove the driveshaft flange, i removed the banjo bolt,transfer case mount, the high/low selector housing, 8 bolts for the main casing, casing, and then 2 switches that were holding up the high/low selector shaft... after that it came out
turbodave
03-29-2019 07:22 AM
lipadj46
02-11-2010 07:45 AM
