help with cdl install i have questions please!
Old May 14, 2010 | 08:04 PM
03discoman's Avatar
Default help with cdl install i have questions please!
hey guys,
i am installing a cdl in my 2003.... i have a complete 2000 disco cdl transfercase that i'm taking apart and i'm running into some problems
here is my progress,
why cant i remove the gear set in picture 3 i've been following the write up....shouldnt the gears just pull out
Old May 14, 2010 | 08:25 PM
03discoman's Avatar
never mind i got it out when i removed all the switches from the main case that sense the high low arm... heres the pics did i do this right? did i get the right t case?
since i had the t-case out of the truck i didnt remove the driveshaft flange, i removed the banjo bolt,transfer case mount, the high/low selector housing, 8 bolts for the main casing, casing, and then 2 switches that were holding up the high/low selector shaft... after that it came out
Old May 14, 2010 | 09:31 PM
03discoman's Avatar
do i even have to swap the gear assemblies or is it just the outer housing......
Old May 15, 2010 | 07:50 AM
Here is a picture of a new kit and the parts that need to be switch over to convert to CDL.
Attached Thumbnails help with cdl install i have questions please!-cdl-diff..jpg
Old May 15, 2010 | 09:28 AM
03discoman's Avatar
so do i even need to remove the gear set from my 2003 t-case? why did they do it on the write up if all you need to swap is the housing?
Old May 15, 2010 | 09:41 AM
You might get in touch with Josh since he wrote the write up and see what he says.
Old May 15, 2010 | 09:49 AM
03discoman's Avatar
i sent him an email.... i havent herd back yet...... i'm comfortable with removing the husing from my 03.... i just dont wanna swap the gear seat if i dont have to
Old May 15, 2010 | 10:40 AM
jycsalas's Avatar
I made that write-up as a guide so it isn't the holy Grail of procedures for doing the cdl swap. And I have only done the procedure once so I tend to forget steps. Lol!
Anyway, pm me ur # so we can figure out what's next!
Old May 15, 2010 | 12:24 PM
03discoman's Avatar
pm sent...thank you sooo much
turbodave
Mar 29, 2019 07:22 AM
hilltoppersx
Aug 15, 2010 12:49 PM
03discoman
May 13, 2010 09:27 PM
NiteTrain
Mar 30, 2010 10:11 AM
lipadj46
Feb 11, 2010 07:45 AM
