Help choosing Shocks
#22
#23
You're thinking about it wrong... OME DOES MAKE stock height springs, they are the height of a NEW stock Disco when it was fresh off the line which was 2" higher than they are now that they've worn out.
Nobody makes a spring the height of your worn out saggings springs if what you are saying is that you'd like to maintain your worn out spring height.
#24
My disco came with rear SLS (air bags), at normal height there were 2" - 2.5" inches between the wheel and the wheel-arch. At raised height there were about 5", about the same as now with the OME 781 coils...
![](http://codeherrings.com/images/auto/rover/disco/coil_swap_11.jpeg)
I chose the OME 781 springs because I didn't want one of the generic no-name brands that come with the coil swap kits. However they are in no way whatsoever stock height. Maybe the OME 764 (220 lb/in vs 290) or something else, I don't know...![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
Thanks again for all the helpful replies!
#25
