HELP!!! Fuel Pump Fitting...where to buy???
Old Aug 13, 2016 | 08:57 PM
Dan7's Avatar
Default HELP!!! Fuel Pump Fitting...where to buy???
Just dropped the gas tank and the green fitting connecting the fuel pump to the rubber line broke in half. It's a simple male (on both ends) fitting, ****** on 1 end and smooth on the other with a retaining clip in the middle. Can't find it anywhere and the car isn't going anywhere without it.
Old Aug 13, 2016 | 09:20 PM
XCELLER8's Avatar
try a good NAPA store.....they usually have a selection of fittings or they could make you something that will work.....they keep all that stuff as top secret behind the counter.....
Old Aug 13, 2016 | 09:26 PM
Dan7's Avatar
Tried 3...struck out
Old Aug 13, 2016 | 11:01 PM
DiscoCam's Avatar
Try clamping on a short piece of fuel line ($5 for 5FT at the hardware store) to the fitting (depends on how it broke off) and the other end to the actual line. At least this will let you drive the car until you can get a proper fix.
Old Aug 13, 2016 | 11:08 PM
jfall's Avatar
Post a picture please.
Well I would use something which will last.
on the Discovery I you can access the top of the fuel tank and the pump via a
round access hatch.
Assuming Discovery 2 the same way.
What ever you do - put in something really good.
You don't want pressurized fuel spraying around when you are under way.
Travelor
Sep 24, 2015 06:11 PM
Rover Nick
Jan 17, 2014 12:02 PM
MeanSaleen
Jul 13, 2013 05:09 PM
me 2
Jul 5, 2012 07:40 AM
JumPeR04
Apr 7, 2011 09:52 PM
