HELP!!!! Headliner removal
Old Mar 24, 2020 | 09:27 PM
Rove Again's Avatar
Default HELP!!!! Headliner removal
Removing the headliner in the Disco II and I’m stuck in the back. Does the trim piece that runs across the top back of the cargo area need to come off? If so, how? I’ve broken a few bits of plastic. Not trying to break this piece!!!! Any advice would be helpful. Thanks in advance!!!
Old Mar 24, 2020 | 09:29 PM
Brandon318's Avatar
It does. It pulls straight out toward the front of the truck.
Don't twist it, just pull straight away from the rear of the truck. It's a series of about 8 clips like the ones that keep the b-pillar trim on. And A-pillar trim too.
Old Mar 24, 2020 | 09:32 PM
Rove Again's Avatar
Ok cool thank you. The trim tools I have done seem to find them. You pull it by hand?
Old Mar 24, 2020 | 09:33 PM
Brandon318's Avatar
Yeah, just get a finger or two under either the farthest right or left side and start pulling.
Old Mar 24, 2020 | 09:35 PM
Rove Again's Avatar
Worked!!!!! Thanks sir!!!!
Old Mar 24, 2020 | 09:37 PM
Brandon318's Avatar
No problem. Good luck with the rest. It's not hard, just voluminous in the amount of trim that needs to be removed.
Old Mar 24, 2020 | 09:58 PM
Rove Again's Avatar
Yeah. B pillar giving me hell now
Old Mar 24, 2020 | 11:18 PM
acg's Avatar
acg
These pics show the position of the clips. Hope this will be useful.
Old Mar 25, 2020 | 08:32 PM
Rove Again's Avatar
Thanks acg. Your pics helped as well. Got it out. Stripping now.
Question tho, what’s the plastic hex nut for on the roof in the cargo area (under the headliner)? Is that to run wiring or an antenna wire?
TRIARII
Jul 18, 2018 05:51 PM
ROB99DISCOSD
Jun 5, 2017 08:00 AM
hhalimi
Mar 9, 2012 02:05 AM
gavone1976
Mar 23, 2011 11:05 AM
AtlGuy228
Jan 4, 2009 07:27 PM
