Help ID suspension knocking up front
Old Jul 19, 2020 | 08:50 PM
sickws6's Avatar
Default Help ID suspension knocking up front
Driving me nuts. Something is knocking up front. I've checked everything. All bushings seem tight with minimal movement. Checked lower and upper shock bushings as well. Also checked all bolts. I'm stumped. It's loud at slow speeds cover bumps. If I rock car side to side I can make it knock but can't locate!
2" springs with terrafirma shocks.
Old Jul 20, 2020 | 06:42 AM
zuke's Avatar
I had something similar. Turned out to be the flat plat on the bottom of one of the shocks was broken. Visual inspection everything looked good. I had to pull it apart to know for sure.
Old Jul 20, 2020 | 06:59 AM
redwhitekat's Avatar
I had the same thing It was my shock
get the front wheels off the ground get a pry bar and try and lift the bottom of shock where it bolts I bet the bearings are gone
Old Jul 20, 2020 | 05:01 PM
XRAD's Avatar
curious: what 'bearings'?
Old Jul 20, 2020 | 08:16 PM
where the bolt goes through the shock itself
Old Jul 21, 2020 | 08:47 AM
sickws6's Avatar
so the shock bushing. I checked those but i will agian.
Terrfirma shocks only last 10k miles?
Old Jul 21, 2020 | 09:21 AM
zuke's Avatar
The lower one where the flat plat goes through the hole
09dewaed
Dec 14, 2017 09:20 PM
avo8230
Feb 18, 2014 06:39 PM
DonRW2007
Oct 12, 2012 06:23 PM
busrider
Aug 1, 2010 04:34 PM
Chrisinhouston
Dec 31, 2008 04:31 PM
