Help! Inspection cover on gear box missing
Hi All,
I am looking at buying a replacement Disco II for one totaled by a drunk driver (not me!). I have found what seems to be a good 2004 at a dealership with low miles (55K). Crawling under it though I found a two minor oil leaks and that the cover for the inspection point on the gear box was missing. Everything inside the case was clean but I am worried about what troubles this could produce. I would like to buy this one as the engine is in the best shape. I have looked at 8 others so far and almost all others have many leaks and condensation and milky goo in oil cap.
Quick advice would be greatly appreciated.
Thanks,
Brad
Thanks,
Brad
Personally, I would be more worried WHY it's missing than the fact that it is missing. Not an area people just go poking around for no reason.
If it's clean in there(use a flashlight), I wouldnt be worried about any issues arising from it missing, but would replace it if bought.
Hi Kenk,
Thanks for the timely response. The car is at a dealership which has done extensive maintenance on it and was then turned over to them after their last round of work (fixing many of the leaky seals). I did talk with the mechanic who worked on it, and he says that he must have forgotten to put it back on.
That alone makes me a little leery of the work ...
sorry, the round the one is the one im talking about too..
LAND ROVER PARTS - PLATE TORQUE CONV COVER, part number FRC7706
the bolts are M6 X 16MM, part number SH106161L
Hi All,
I am referring to the round inspection cover.
My apologies for not giving an accurate description. I was looking through the RAVE manual trying to find the actual name for it but never found it.
I can't tell all of you guys how much I appreciate this site though. It helped me through some of the fixes on my old Disco, but I am certainly still a newbie when it comes to fixing these things and the correct terminology.
BradSwanson
Feb 25, 2012 01:32 AM
