HELP! it's scaring me!!!!
ok just got my 2000 discovery 2 months ago now all my dash light's are comming on last friday the SRS light came on and today the ABS light Traction control light and the hill descent light with an! after it in the lower left hand of the dash. what is going on whith this thing????????
on
RE: HELP! it's scaring me!!!!
The SRS light is on because of a possible air bag or seat belt problem, that will have to be checked by the dealer.
The other brake likes came on because of a glitish in the ABS. What were you going when the brake lights came on, do you brakes squeak, or the wheels covered in brake dust?
Mike
Mike
on
Wdriving down a dirt road can trip out overly sensitive brake system. Mine go on once or twice a year, but I am pretty hard on my truck, usually happens when brakes are hot, have too much dust on the rotors and one of your wheel sensors will tr=hrow a false code. When most shops read the codes, it will usually show a bad wheel sensor when in fact it was heat and dust.
Hose your brakes out and go have the codes read, if it is a wheel sensor let the shop you want to drive the truck for some time and see if they come on again. If the lights don't return with in a week you are OK, if it does return, plan on replacing a sensor.
Good luck,
Mike
Good luck,
Mike
ok im now noticing the abs comming on when braking...even very easy. it seem's to be comming from the front psgr wheel...im going to try to clean it out today and seeif the light goes out .but im thinking it's a bad speed sensor. anyone in massachusetts know where there is a place that can read my coads without going to LR im in se mass....
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
