Help M A P sensor location 2004 disco 2
Yeah I'm sure that's what the code came up with cause I've tested the MAF it was easy to locate but the codes are coming up with 1/2 O2 sensor's vac leak and Map sensor fault I checked for vac leaks with starter fluid nothing then i talked to friend and hes said the map can cause false readings for the o2 and vac leaks but I can't find it
