Help me fix this leak - transfer box
Old Jan 30, 2013 | 08:30 PM
SWAINROVER's Avatar
i had this problem in october did a reseal on the box was 1000 dollars ..two months latter tran box gear went out had to get a new tran box think twice starting looking for a rebuilt one dont wast your money ..mine had 135,000 miles on it
Old Jan 30, 2013 | 10:18 PM
antichrist's Avatar
I seriously doubt he's going to spend $1000 on a seal and a nut.
$20, maybe.
Old Jan 30, 2013 | 10:24 PM
taylor15's Avatar
Yeah about 22 bucks shipped, unless the flange shaft is grooved. I cannot believe someone would charge $1000 bucks for a box reseal! I don't think I have any further problems with the box, and if it wasn't leaking on the exhaust and burning off (creating bad fumes in car) I wouldn't be extremely worried about it now.
Old Jan 31, 2013 | 10:15 PM
taylor15's Avatar
Originally Posted by Disco Mike
You might want to inspect the flange shaft and make sure there are no groves warn into it, if there are, you should replace the front flange cause it will just start leaking again.
If the flange looks grooved, is this the correct kit?Transfer Box Output Flange Kit Front (Part # STC4379) - Land Rover transfer box from Atlantic British
Also, is there a way to tell if it's grooved before I pull it?
Old Jan 31, 2013 | 11:38 PM
antichrist's Avatar
Yeah, that's the kit, but if you've bought the seal and nut you don't need another.
You can't tell if it's grooved without removal.
If you can have it down for a while, if it's grooved then take the flange to a bearing shop, there's a good one on Fulton Industrial, and have them measure it to see if the speedi-sleeve PN I gave you fits. They are about $30 or so.
Old Feb 1, 2013 | 06:05 AM
taylor15's Avatar
Thank you. I am going to pull it on Saturday and go from there. Sorry for all of the questions, I am still learning to wrench on cars. I've worked in boats my whole life, but the only part so far gone wrong with the rover is drive train. Go figure
Old Feb 28, 2013 | 09:43 PM
taylor15's Avatar
Update:
I decided to hold off on this project until I could also do the front prop shaft. I am looking over the rave right now since I have all the parts finally and have a few questions before I get started.
1. They use a tool to restrain the drive flange. Is this necessary?
2. Will I need to get a special tool to remove the flange?
I think this is all for now, otherwise it looks pretty straight forward.
Juergen33911
Jun 19, 2013 12:49 PM
lipadj46
Jul 8, 2009 07:41 PM
sunshineking
Jun 6, 2009 09:25 PM
Fyko
Defender
Jul 10, 2007 07:05 PM
ant996
Defender
Sep 14, 2006 05:03 AM
