Help me with these tow wheel/tire options, see pics!
1. Stock 18's with brand new Cooper Zeon LTZ 285/60/18. Done for $800
2. 16 Rims off craigslist for $200 then GY Duratracs 245/75/16.
Concerns:
-Coopers rub up front at steering lock, are 10lbs heavier per tire than the Duratracs.
-Don't wanna lift, wanna keep C of G low.
-Don't wanna modify axles and gears.
-Need spacers at least up front to clear steering rub
-Concerned about loss of articulation space with such a big tire (Coopers) while off road
-Coopers are nice and wide and stable, Duratracs are narrower, on a narrower rim.
-Concerned about safety/traction in the snow
Truck is a daily driver, 1 mile to work! and we take it to mammoth skiing and to desert camping, no crawling.
Here are pics of mounted Coopers:
![](https://farm6.static.flickr.com/5295/5407514285_80dffc56ff.jpg)
![](https://farm6.static.flickr.com/5131/5407503159_ef481f2e06.jpg)
Concerns:
![](https://farm6.static.flickr.com/5173/5407506261_176596615f.jpg)
![](https://farm6.static.flickr.com/5219/5402415297_542e9b3b05.jpg)
so what is you question? the tires on the 16" rims will be one inch smaller in height and thinner. so if you are looking to take a step back and not have to worry about rubbing than go with the 16's. but you don't need spacers you can adjust the bump stops if its hitting the radius arms. i think the good year is a better tire for when u head off road but with a 1 mile commute how is you MPG a problem?
Don't really care about MPG, in summer I walk or ride my bike to work, Disco is for bombing around town, fun and trips!
neither are going to put excessive stress on the drivetrain if that is what you are worried about. personally i would go with the 16 inch rims with an A/T tire. The Cooper Zeon is a hybrid street A/T where the goodyear is a straight A/T. BUT i would say check these out before you get the goodyears http://www.treadwright.com/p-34-245-...den-a-t-e.aspx
Just got off the phone with my tire guy and he is totally willing to exchange the Coopers for Duratrac's 245/75/16 if I get rims. He is awesome, I would recommend if in San Diego, http://sdtireandwheel.com/
Considering this because my independent Rover shop say the Coopers are just too big. (He also recommends an LR3!)
Also Duratrac is an all around better tire for snow/off-road traction.
Thoughts....?
Those coopers are not too big and won't put too much extra strain on the drivetrain. They are really heavy duty tires actually and should wear pretty well. As far as the rubbing you need to put hub centric spacers on the front and do some major trimming. That being said if you can get the duratracs on 16" wheels go for it.
