Help!! no oil pressure.
Old 12-18-2013, 09:41 PM
xxdoylexx's Avatar
Wanna stop yor girlfriend from helping you with your car? Marry her...
Old 12-18-2013, 11:42 PM
White Rover's Avatar
Well that's a thought but I think I'll hold off its nice to have an extra hand at times! Haha well I guess I'll tear the cover back off tomorrow and double check everything and use Vaseline insted of assembly lube.
Old 12-19-2013, 06:02 AM
drowssap's Avatar
unfortunately; i think you are going to have to go back into the front cover again. Vaseline, assembly lube, oil it should not make a difference. It is only used to keep the oil pump from galling on start up. it is possible that the check valve in the pump assembly is hung up?
Old 12-19-2013, 09:16 AM
It's possible that something could be hung up or stuck open it was a used front cover mine had a crack where a cooler line goes. I'll check all that today at least the pan is already off. Thanks for your help its greatly appreciated!
Old 12-19-2013, 12:03 PM
turbodave's Avatar
Did you change the pump becuase you had no oil pressure?
Before I figured it out, I spent hours trying to get oil pressure cranking the engine.
The specialists in the UK just start the engine. oil pressure is easily attained at idle speed it seems - but not neccesarily at cranking speed.
oil pressure (lack of) on cranking? - DiscoWeb Message Boards
Old 12-19-2013, 01:51 PM
I had a crack in my front cover so I decided to change the oil pump while I was there. I did start the engine and let it run for 10 to 20 seconds but it started getting loud so I shut her down. I'll check out the link now thanks!
Old 12-19-2013, 03:12 PM
acamato's Avatar
When you installed the new gears, Did you pack the oil pump with vaseoline?
Old 12-19-2013, 03:33 PM
I packed it with white assembly lube.
Old 12-23-2013, 10:09 AM
Well I finally got oil pressure last night from another used front cover. I pulled the oil pump cover off the one that wouldn't build pressure and everything looked fine, its another rover mystery! So at last the truck is back on the road and I'm a pro at changing the oil pan and front cover! Thanks everyone for all the help!
Old 12-23-2013, 10:13 AM
drowssap's Avatar
that sucks, but its good you didn't give up; a lot of people would have. good luck with it
Quick Reply: Help!! no oil pressure.
