Help no power to the wheels bearly accelerates.
Old Apr 24, 2022 | 12:05 PM
Khail Hartman's Avatar
4th Gear
Default Help no power to the wheels bearly accelerates.
So I do alot of side jobs on rovers, I have rebuilt so many D2s I can't even count and have never had this problem. 2004 discovery se with the 4.6, customer asked for more power I guess it could bearly get up hills, he dropped it off as a non runner and to my surprise he somehow melted the wiring harness coming from the fuse box it found its way on to the manifold and caused so many problems. I replaced the harness and during so found that he blew a headgasket and the engine was toast. I pulled it took it all apart and sent it to the machine shop had the heads shaved and block pressure tested ect. For power I thought maybe a high lift cam will help so when I rebuilt it I put a half inch lift cam accompanied with a cool air intake and high pressure fuel pump. After putting the engine back in it ran perfect with no codes except a permanent voltage supply code. It had some leaks I spent the last couple of days fixing and today when I took it out on the road it had absolutely the worst acceleration I have ever seen it's so bad it would take all day at open throttle to get a 0-60 time. I have never had this issue with one of these usually I rebuilt it, it runs great and it's on to the next but at this point I'm at a loss. Any ideas would be greatly appreciated almost everything is practically new, the only codes present are permanent voltage supply, then for abs it says rear left and right sensors are open circuits.
Khail Hartman
Apr 26, 2022 08:53 AM
velija
Aug 24, 2016 02:31 PM
Avery Hindman
Engine & Internal
Jan 10, 2014 03:09 PM
Avery Hindman
Jan 7, 2014 09:59 PM
Shawn Cross
Dec 19, 2012 01:31 PM
