Help with OBDII code P0153
O2 sensors
I'm not sure if they changed them or not. I purchased the car shortly after that had been done. It is sitting about 98,000 miles right now. Given the code, I would have to guess that the dealer did not change them, or else the previous owner elected to not change them.
Sorry I'm such a noob, but I have to ask a couple of really stupid questions. How many are there, and where are they located? I'm pretty handy with a wrench, just not all that familiar with this O2 sensors. Thanks.
Todd
Todd
Now look back right before the two pipes come together into a Y in front of the large muffler in the center. Those are the downstream O2s.
The connections are somewhat annoying to get to (especially the passenger's side downstream) but totally do-able. Do make sure you get a proper O2 socket or use a 6-point line wrench. You may not need it, but it's better than rounding one off with a standard open end wrench and having to pull the y-pipe to get the old one out/patch/re-bung.
workinghard1713
04-16-2012 11:25 AM
