HELP with P0332, in northern Baltimore County
Old Sep 4, 2016 | 07:32 PM
Fatkid81's Avatar
Default HELP with P0332,
So, I've read all the post on this code. I've replaced my KS and Camshaft Pos Sensor. As of right now it's no longer a hard code but pending. right around 2200RPMs it does it. when i first replaced the KS i had to replace the plug being it was pulled out at the sensor. I've also gone back and made sure i had them spliced together good. I've wrap the **** out of them too.
I need to replace the driver side exhaust manifold gasket, and valve cover gaskets. I have a sound that I can't tell if its the manifold gasket or a collapse lifter. Tomorrow i'll add the sound. So would the manifold gasket be whats throwing this code? or if your in the northern baltimore county and know a lot about D2 i could use a hand.
Richard.rover
Jan 17, 2022 03:49 PM
jrm123180
Feb 24, 2012 12:24 PM
afortiori
Oct 31, 2011 11:01 AM
vetteracer79
Feb 18, 2009 09:45 PM
Aj6543
Nov 11, 2008 09:00 AM
