help p1230!!
I am aware of the different relays and their numbers, but unless yours is for some reason different their is only 1 #4 relay, that is why I thought you might have installed the wrong one.
Glad you found the problem, did you replace just the motor or the entire pump housing assembly?
Thanks Joe
on
I went and rechecked my truck to make sure on the relay. There are, depending on your options, 4 yellow relays in your holder, only 1 is stamped with a R6l2 numbers, which is the for the fuel pump, the reset are Rl63 or Rl64 relays, so if you swapped relays, you have the wrong one in the fuel pump socket, the others won't work.
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
