Help possible heads gasket issue ?
So , I was replacing my front crank seal it was leaking bad , when I was under it I noticed bottom of the r head is leaking oil.
Im also getting a bunch of white smoke during startup that goes away after it warms up, it runs good so I’m kinda confused .
So, im thinking about doing the head gasket is there any way to tell if the block is cracked under the liner ? Don’t want to waste money
Thanks
Just did a 3” tf hd lift
Thanks
longtallsally (12-09-2022)
You can;t tell if the block has a crack unless block is out and pressure tested......oil leak could be valve covers....
as far as bad head gaskets, this is ALWAYS a possibility (probably more likely than not)......does your coolant level keep dropping?
mileage?
Nice color and good looking disco!
mileage?
JohnZo (12-11-2022)
Ivan_Drago
07-29-2019 05:12 PM
