Help problems
cisney
Junior Member
Help problems
got a 2000 disco with some problems i have yet to figure out. It was driving like it was running out of gas or maybe the trans. was going to drop I dont know so i took it in. they couldnt find anything wrong with it. couple days later it did it again but much more severe so i took it back no codes so i had them put new plugs in. drove like a dream for a DAY! no check engine light nothing the next day it was all back but worse. so I replaced the wires, the plenum gasket. ran some sea foam thru it and some engine stuff in the oil. still the same, but getting worse. took the 02 plugs off to see if the converters were pluged loud but still no power. idles great but if try to drive it check engine light flashs no power going up hill ,vibrates etc WHAT COULD IT BE AHHH sratching my head any help would be greatly appreciated. keep in mind im not a mechanic. id id have the head gaskets and coolant system redone awhile ago not long enough for it to be a problem it does have 230,000 milesbut starts and idles like a dream always put good gas in it and synthetic oil changes. thanks
Junior Member
Help problems
I feel like your symptoms are somewhat simliar to mine and mine apparently is misfiring cylinder....At least the lack of power and vibration and that feeling of running out of gas im assuming is the car feeling like its choking or something.
cisney
Junior Member
Help problems
Junior Member
Help problems
alti
Mar 13, 2013 08:30 AM
Speed racer
Oct 11, 2008 10:56 PM
