Help with roof leak
Old Aug 6, 2012 | 08:22 PM
sorbet35's Avatar
Default Help with roof leak
Hello All,
I have an 04 disco and every time it rains hard i get water dripping in through the roof liner by the passenger window.I used silicone around the roof bar but it didn't work so im stumped..........Thoughts
Old Aug 6, 2012 | 08:31 PM
nahtanoj's Avatar
i've got it at the drivers window, and i have no sunroofs. probably gonna have to pull the headliner to see what's really going on. my guess for me is te roof bars.
do you have sunroofs? it could be a clogged drain line.
Old Aug 6, 2012 | 08:54 PM
sorbet35's Avatar
i have a sun roof, but the leak is over by the door,this is a hard one
Old Aug 6, 2012 | 08:59 PM
Racer X's Avatar
It's your sunroof, the water just runs atop the headliner until it gets to the door and pools up.
Old Aug 6, 2012 | 09:33 PM
sorbet35's Avatar
I will check it out.......thanks
Old Aug 7, 2012 | 09:10 AM
You will probably find either the tube is broken loose from the collector box or is cracked.
Old Aug 7, 2012 | 10:00 AM
Jadreigo's Avatar
My 2003 Disco II leaks pretty bad from the top of rear door (i.e. tailgate), I have sun roof's but not yet sure wether water is coming from door frame seal?
If it is coming from the sun roof, how do i check tube/collector box conditon? Is it an easy fix?
Old Aug 7, 2012 | 10:32 AM
FLDiscoII's Avatar
The rear tailgate is notorious for leaking. Mine would pour any time that it rained. I ended up having to adjust the latch as well as the hinges. Got the door aligned, no more leak.
Old Aug 9, 2012 | 11:00 AM
DUBLJDISCO2's Avatar
Where are these drain tubes located and how can I get to them? Thanks
Old Aug 9, 2012 | 12:51 PM
FLDiscoII's Avatar
The only way to get to the tubes is to drop the headliner board. The drain tubes run off of the two front corners of the sunroof frame.
