HELP! Runnig Rough Sluggish -- CEL
Old Mar 6, 2008 | 02:46 PM
  #21
JPC97DiscoSD's Avatar
Default RE: HELP! Rough Idle, Vac hose???
I believe the cracked hose was the pcv hose? would this cause my problem i ducted taped back up until i order a new one
Old Mar 6, 2008 | 03:23 PM
  #22
ok mike i will give you a call in about an hour or when i get home thanks for the help thus far
Old Mar 7, 2008 | 05:50 PM
  #23
ok now my disco is running rough when i drive it and does not have much power i took the plugs out and this is what they look like i put them in only 50 miles ago. the tip is white and the rest is dark they were NOT wet when i pulled them. let me know what you guys think.
Old Mar 7, 2008 | 06:06 PM
  #24
does the white mean i am running lean? or am i running rich? thanks
Old Mar 7, 2008 | 06:37 PM
  #25
Hey DiscoMike is it alright if i give you a call right now?
Old Mar 8, 2008 | 08:01 AM
  #26
Yes a vacum leak will cause rough idle, take your PCV hose down to NAPA and buy a couple of hose clamps and have them cut you a foot of vacum or gas hose, go home and cut it to length making sure that you dont kink it, also replace the hose coming from the valve cover to the throttle body.
Then clamp them so they make a tight seal. I did the same thing on my '97.
The idle control valve being bad will NOT cause a rough idle, it just wont idle when that goes bad.
Go to NAPA, spend the $5 and fix your trk.
If you slip the AutoZone guy reading your codes $10 he will clear them.
Old Mar 8, 2008 | 10:48 PM
  #27
Alright thanks i will go to NAPA and do that. Thanks again i will keep you guys updated. Any know what the color of the spark plugs mean? Thanks
Old Mar 9, 2008 | 08:29 AM
  #28
jkid's Avatar
A lot of white, blistering means you are running too hot, yours look a little too white. Usually its from using the wrong plug, bad timing, sticking valves, poor cooling, etc... In your case it sounds like the vacuum leakmight causing it too run too lean and therefore hot. So, change your plugs while you're at it.
Edit: Get your codes cleared and see if any others come up later. Bad O2 sensors, air flow sensors (any air/fuel metering)and such could make it run lean toobut those would give a code.
Old Mar 10, 2008 | 06:35 PM
  #29
Ok i brought a coder reader today and here are the codes:
P1193
P0300
P0308
P0304
P1316
P1314
I cleared the codes it still is doing the same thing i drove it around my block and let it idle for 3min since i cleared them and no CEL lights came on.
Old Mar 11, 2008 | 04:43 PM
  #30
Should i drive the car more until the codes pop up again or will it damage my disco more?
