HELP! Runnig Rough Sluggish -- CEL
Old Apr 21, 2008 | 06:41 PM
  #61
jdhuegel1's Avatar
Default RE: HELP! Rough Idle, Vac hose???
Fuel filter was pretty tough, but I liquid wrenched it for 2 days. Mission accomplished!
Spike - thanks, hopefully it works! Fingers crossed.
Old Apr 22, 2008 | 09:50 AM
  #62
britishracinggreen's Avatar
Does anyone have any recommendations for replacement O2 sensors? Will any four wire O2sensor work? Cheapest I can find them is $150 each.
Old Apr 22, 2008 | 10:12 AM
  #63
Go to , http://www.roverconnection.com/ for the best price of 02's for your truck and make sure you have your vin with you when you order cause there are 2 different styles used.
Old Apr 22, 2008 | 12:45 PM
  #64
jdhuegel1's Avatar
While waiting for my O2's I decided to clean under the hood... (Obvious the previous owner didn't even know how to open the damn thing...) well guess what I find? The passenger (US) freakin PCV hose is disconnected. It was sitting where it is supposed to go but I just looked it over... Needless to say, when that nipple isn't drawing in atmosphere the truck runs a WHOLE lot better. It idles like new and drives with only minor hesitation which I think will be fixed with the 4 new O2's. Before I had to beat the crap out of it just to get to 55mph... now it CRUISES there.
Thanks for the help again Disco Mike. You sir, are the man.
Justin
Every day is getting better... I'm loving this truck more and more!
Old Apr 22, 2008 | 02:28 PM
  #65
jdhuegel1's Avatar
Oh and interestingly enough - I found two dead mice under the sagging hood-liner. They'd been there for years it appears. I was going to 3M it back up there but screw that. Guess I'll try to source a new one.
Old Apr 24, 2008 | 09:13 AM
  #66
cptshanman's Avatar
Hi all. Looking at the site (roverconnection)for the magnacor wires and O2 sensors. Found that the magnacor wire description table says "replacing intake manifold gasket may be required)" for the Magnacor 8mm wires.
Question 1: What does this (the above)mean?
Also, running into similar problems at take off with my '99 disco II. backfiring occassionally, sluggish for the first second or two (afterpressing accelerator)then takes off normally. I figured this is so close to the same thread topic that I would stick with the ongoing thread...
I am sure the truck needs much maintenance. It has just under 150k.
Question 2: Will replacing the O2 sensors early on in the tune-up process cause damage to them or can I replace them immediately?
gretaweaver
Jul 9, 2013 10:20 PM
Bamberson
Mar 14, 2012 04:57 AM
lyleorszulak807
Feb 3, 2011 09:40 PM
tsuami1
Jan 26, 2011 10:21 AM
Fobra
Jan 25, 2010 07:54 PM
