Help with some codes.
Hey guys after some good months of no trouble I got some codes yesterday. I suppose I was over due for some.
I got the following:
P1884
P0441
P0445
The two last ones are O2 codes right? If it helps I did replace the valve cover gaskets a few weeks ago, but I went on a long trip to the mountains right after that with no trouble.
The OBD II scanner at autozone says P1884 is an engine coolant lamp circuit short to ground. Any usual suspects?
Thanks as always
P1884
P0441
P0445
Thanks as always
Ok well I replaced the purge valve and the codes have come back this time I got the following:
P1668
P0441
I need to track down this canister vent selenoid, someone on this forum has to have done this job before.
And I guess I'm getting alternator issues now?
P1668
P0441
