HELP!!!! (TC) keeps enaging
Old Apr 11, 2018 | 06:06 AM
CollieRover's Avatar
Originally Posted by Rovingwild
Update, I was able to get the situation to improve by using compressed air but no the ABS/TC engages when starting from traffic light. Let off the throttle and then it acts normal and will accelerate as normal until you have to stop again. Also occasionally during turns. Unable to get codes cause I dont have anything to interface with SLABS. Do I just get new Hub bearings for both front?
I'm surprised you are not getting the Three Amigos, but this sounds like a sensor. You can grab a cheap one from ebay that has the original connector, and fix it easily. This is exactly what my truck would do when I had a bad front sensor, but the Amigos would go off.
Old Apr 23, 2018 | 02:57 PM
stxscott's Avatar
Just had the same issue. I rushed the rebuild and on one side I felt the speed sensor didn't seat correctly. I had the TC kicking in especially when turning right.
I found some local o-rings (1.5mm 17/19mm that seemed about right) and replaced the one that hadn't seated. TC stopped, but then I got the FOUR Amigos ('03 D2). ABS/TC/Hill Descent/Brake.
I tried cleaning out that hub but didn't help. Next I'll try cleaning out the other side too. I've ordered a new scanner because mine won't read the abs data.
Just wondering what the specs are on the O-ring are and if the one I used was ok?
Old Apr 23, 2018 | 05:19 PM
Rovingwild's Avatar
From: Maryland is homebase but we troam the globe in search of great views, good food, and new friends
So I purchased two new cheapo ABS sensors on ebay. I went to replace them and noticed that the ABS sensor wasn't seated flush and that may have been causing my issue. I installed the two new ones and within 10 miles I got the Three amigos. Stay tuned......
Old May 4, 2018 | 03:07 PM
stxscott's Avatar
I got a icarsoft scanner and it indicated the right front sensor was bad. I am waiting on a new sensor too - first one received was a rear (too short) but vendor is sending me the proper one at no extra charge. Hope this solves the TC/4 Amigos issues.
Old May 4, 2018 | 03:58 PM
Rovingwild's Avatar
Scott which ICARSOFT scanner did you buy? I tried searching Amazon but so many came up. Thanks.
Old May 5, 2018 | 07:25 AM
stxscott's Avatar
I got the icarsoft LR II
I updated the software without issue following the instructions on their website.
I think the interface is a bit clunky, but haven't fully 'played' with it yet to get to know how it works best. Documentation seems to be lacking. I didn't mind buying this model because I know that some time in the future I plan on a Jag XKR
I have an ultraguage and other scanners but none read the ABS stuff.
Old May 13, 2018 | 07:10 AM
stxscott's Avatar
Replaced front sensor and reset codes Friday night. LRD2 seems to be fine now. Only two concerns.
1) The right front sensor runs thru the wheel arch to a connector. The male part of the connector (harness side) almost disintegrated when I removed the old sensor. I had to fudge it together and wrap in tape. If anyone knows the wiring from the sensor connector to the unit, and if this is replaceable please let me know.
2) The o-ring I used was one I found locally, not sure if it is the right spec but seems to be ok.
All in all I'm glad to have new ball joints and my 4-amigos resolved.
Old May 13, 2018 | 03:37 PM
OffroadFrance's Avatar
X1 ............ The cables on the front sensors fracture due to steering use over time and often throw the 3 Amigos. Try fitting 2# new front sensors then clear down any codes.
BigDogg
Jul 4, 2012 09:24 AM
sarahgibbons5
Jun 14, 2009 11:36 AM
wydell
Jun 11, 2009 12:40 AM
chiasurf
Jan 31, 2009 04:28 PM
