HELP! tie rod
Old Oct 14, 2023 | 02:39 PM
Killerkaw's Avatar
Default HELP! tie rod
Kroil....heat...cold.....left hand thread.... welded blocks to keep from moving..... I'm all but convinced it's not designed to come off. Any advice
Old Oct 14, 2023 | 05:51 PM
mln01's Avatar
Just replace the drag link and track rod with a heavy duty set from Rovers North.
https://www.roversnorth.com/parts/rn...eering_rod_set
Old Oct 14, 2023 | 09:23 PM
Killerkaw's Avatar
Yes, that's an option.... but does it actually come out?
Old Oct 15, 2023 | 05:53 AM
keninnc's Avatar
yes it comes out, just not worth the hassle
Old Oct 15, 2023 | 10:20 PM
Killerkaw's Avatar
I think it was factory crimped so it can't come out.
Old Oct 15, 2023 | 10:59 PM
miron's Avatar
It should, i was about to replace mine, but price wise getting the terrafirma made more sense. If you live in Seattle are you can have my old pan hard bar and tie rod, if you don't want to go the "upgraded" route.
Old Oct 16, 2023 | 08:40 AM
Killerkaw's Avatar
Thank you for the offer, I'm on the East coast though. I've already ordered one.
BUT... knowing I've ordered one and not being one to be beaten by what is just a special bolt in a pipe I threw caution to the wind. I welded two flat plates to the tube because it kept spinning in the two vises i was simultaneously using to hold it. So with the pipe in the fixtures, liberally soaked in kroil, with an appropriate application of heat,and using an industrial pipe wrench, with a 4' breaker pipe over the handle. I almost ripped the vises from the table using clockwise torque (left hand thread),
It never budged. I've conclusively proven Land Rover didn't intend for it to be removed
Old Oct 16, 2023 | 10:31 AM
Harvlr's Avatar
East coast (salty roads) might be the answer. When I did my 1963 2A it took a lot of heat from a torch to get it to budge (very corroded).
Old Oct 16, 2023 | 11:31 AM
Killerkaw's Avatar
No salt down here in SC. No evidence of corrosion either, (can't see the threads though)
as far as heat goes, i propaned it to almost red. That didn't work, i figured the heat from welding would have shocked it free (usually works)..... nope
Old Oct 16, 2023 | 06:39 PM
Harvlr's Avatar
Wow! That sounds tight!
