Help on timing cover replacement?
Old Mar 14, 2011 | 08:10 AM
drowssap's Avatar
one thing you may want to keep in the back of your head is to break free the bolt on the harmonic balancer/ lower pully before removing the belt, other wise the crank will just spin, of course if you have standard you can just but it in gear. There are other ways but just having done it it would have been quicker and easier to break it free while the belt was on.
Old Mar 14, 2011 | 01:48 PM
univu2's Avatar
Default Job done
Thanks for the tips. Bosshogt, I ended up using valvoline multipurpose high temp grease (614) on the output oil seal that goes on the timing cover/crank shaft. I'm thinking I might put some other tips/observations on a new thread to try and help others save a bit of time.
MattyMatters
Nov 17, 2016 04:39 PM
A5scott
Jul 11, 2015 07:25 PM
Marni
Jun 30, 2013 09:36 PM
tmtegt
Mar 20, 2013 07:31 AM
neroverguy
Aug 19, 2010 12:58 PM
