Help! What are these two vacuum lines??
Old Sep 29, 2019 | 11:22 PM
jrncsmith's Avatar
Default Help! What are these two vacuum lines??
So I finally am wrapping up my head gasket job on my 2004 Disco II with supplemental air after a several weeks delay when I came across these two vacuum lines? Despite my notes and photos I can not figure out what theses are? The top photo is of the back left valve cover with a small black plastic tube with a hard bend (there is another next to it that comes up from the back of the engine and back down towards the transmission. The second image is another small black straight plastic tube attached to a plastic clip on the firewall to the right of the engine. Can anyone ID them and tell me what they need to hood up to? Thanks in advance!
Old Sep 30, 2019 | 03:36 AM
JUKE179r's Avatar
They are air vent lines for your automatic tranny box and the other is for the front differential as is a third air vent line in your rear diff also.
They are much needed.
Old Sep 30, 2019 | 10:09 AM
jrncsmith's Avatar
My first thought of the one located behind the left valve cover was that it was a breather tube so that is good to hear. With that, nothing to hook up obviously. The other straight one attached to the right side of the firewall; are you sure??? It seems like a very odd place for a vent and you would think it would also be hooked at the end to deter material from getting in. It really looks like something different from a vent tube.
Old Sep 30, 2019 | 11:34 AM
mollusc's Avatar
it's a vent tube. seriously. if you really want confirmation, trace it back to its source.
garthbrooks
Range Rover Classic (1st Gen)
Sep 27, 2019 07:57 AM
sayeedA
Feb 15, 2017 01:54 PM
mcaz
Jan 13, 2017 07:20 PM
Rover Newbie
Jul 1, 2014 02:07 PM
Charlie_V
Jan 18, 2014 09:53 AM
