Helpful suggestions please
That has been my plan, to get the rave manual and work my way up. It's frustrating that my discrepancies are connected to something else I should replace as well. Like the spark plugs and wires...if I have to take the manifold off to get there I might as well do the gaskets. And doing the brakes I might as well get the hubs and replace all of it. I'll just have to steadily buy parts and download the manual and do what I can... Seems like by this time next year I'll be a lot more knowledgeable..... Or I'll have killed my disco haha
Pick off things one at a time.
First is coolant leak, if Steel Seal work, you have that off your list.
Second is Drive Shaft, The Drive Shaft is a fairly easy job 8 bolts to take it off. You can rebuild it or have a driveline shop rebuild it. (Also, check front drive shaft).
Head Gasket, it is a $2000 or less job. Any shop can replace your head gaskets, the only tricky part is the torquing of the new head bolts.
Brakes, are a 30 min per wheel job and parts are about $150.00 per Axel for pads and rotors.
Misfire on Cylinder One is more than likely a bad plug, so go out and buy a new plug replace it, clear the codes and see if it comes back. If it does comeback you need wires.
You should also buy a code reader so you can clear your codes and get your codes. Target Price depends on what you get. By my readings if you have a PC buy a Autocom CDP+
https://landroverforums.com/forum/di...n-video-62986/
This forum goes into that. Once you have your codes post them and people will help
Marni
12-28-2011 05:17 PM
crystalsky8379
08-09-2010 11:08 PM
Gordon Bombay
12-20-2009 08:22 AM
