Here are the differences between a generic and Airtex water pump...
Old Dec 29, 2020 | 11:01 AM
Brandon318's Avatar
Default Here are the differences between a generic and Airtex water pump...
I installed a generic ($80-ish) water pump in the disco last summer and 10K miles later, a squeaky pulley noise and gurgling heater core ensued - sure enough, the water pump bearings went bad as evidenced by a small glob of dried coolant beneath the weep hole. Should've sprung for the Airtex (about $150) the first time around and increased my chances of avoiding this. Anyway, pulled the old water pump and yesterday installed the new Airtex. Thought it might be helpful to show some of the differences between the two. Overall theme seems to be a much better casting designed to flow water more efficiently. The bearings are probably better and the impeller mount looks different enough to support that assumption.
You can see on the generic pump that there's a hard lip where the flow is supposed to transition nicely into the coolant galleries. And anytime there's a wedge shape in the casting, the generic one is more blunt, whereas the Airtex transition comes to a sharp point, again, better for fluid flow.
Old Dec 29, 2020 | 02:32 PM
redwhitekat's Avatar
They look very similar. They just usually fail at the seal where impelar is It’s a hit and miss with these parts
Old Dec 29, 2020 | 10:35 PM
boston4's Avatar
Where’d you source your generic pump? Asking from someone who installed a Lucky8 water pump 6 months ago.
Old Dec 30, 2020 | 07:24 PM
Brandon318's Avatar
Atlantic British. It was their not-Airtex option. I talked to the guy there, Dave, and asked, if these things fail so often, why do you guys even sell them? The answer you'd expect, which was simply that they need something at that price range even though they're garbage.
Old Dec 30, 2020 | 08:45 PM
zski128's Avatar
I got my airtex water pump from Rockauto for around $65. I believe it was made in Spain and seemed well built. Time will tell I guess.
Old Dec 28, 2024 | 11:48 PM
Athana's Avatar
Hi how is the Airtex Water Pump holding up ?
Mine failed in two years 208k to 228k
Old Dec 29, 2024 | 10:16 AM
Brandon318's Avatar
My failed in two years 208k to 228k
So far still holding up great! It's the longest I've ever gone not having to replace a water pump on these old boys.
Old Dec 29, 2024 | 11:24 AM
longtallsally's Avatar
What is the collective’s thoughts on Flowkooler? I put one in the Alveston and have been extremely happy. It’s been 2 years and 6k miles? Zero issues.
Old Dec 29, 2024 | 11:32 AM
Brandon318's Avatar
Whenever I have to replace this one, that’s the pump I’m putting in.
Old Dec 30, 2024 | 08:27 AM
Athana's Avatar
The Airtex OEM from Atlantic British was installed September 2022 (208k) and failed December 2024 (228k) that makes it a piece of China made junk.
The original was in there for 200k miles.
It seems the original was made in Europe and were discontinued.
