Here are the engine to transmission bolts
Old Mar 14, 2017 | 09:13 AM
twin6's Avatar
Default Here are the engine to transmission bolts
If you are removing your engine without removing the transmission you will need to remove (14) 13mm bolts. They are very highly torqued and they will require a breaker bar. Take your time, four of them hate you. Just keep your head about you and remember you are the human.
I have attached a photo to help guide you where these are. The bolts at 3:00 and 9:00 seem to be the hardest to see and hardest to remove.
I did not remove the front pipe, just the exhaust manifolds. I also did not loosen or remove the crossmember.
Old Mar 14, 2017 | 11:38 AM
The Deputy's Avatar
Nice diagram/picture. But, bolts 3 + 4 heads face the rear of vehicle and thread into the oil pan. Not a big deal, since they are out in the open and probably the two easiest to remove.
Brian.
Old Mar 14, 2017 | 11:57 AM
twin6's Avatar
You are certainly correct. I missed it since those are through holes (not tapped) and tapped into the oil pan as you say.
Old Mar 14, 2017 | 03:20 PM
The Deputy's Avatar
That just goes to show ya...I spend way, way, waaaayyyy too much time lying around under our two Discovery's...lol.
One, installed a trans. and the other has the engine out at the moment.
Brian.
Old Mar 14, 2017 | 03:36 PM
KingKoopa's Avatar
Really wish the brits didn't have the habit of over engineering where 4 easily accessible bolts would do and under engineering where they definitely could have used something more stout.
Old Mar 14, 2017 | 06:54 PM
twin6's Avatar
Corrected it. Can't let that one go. Thanks for pointing it out!
Old Mar 14, 2017 | 06:55 PM
twin6's Avatar
Amen to that.
I have owned many a Brit car but this Rover's engine was the hardest to remove by far. Also, Jeeze! The torques on everything is crazy high.
Old Apr 20, 2017 | 11:31 AM
shady milkman's Avatar
The number 3 and 4 bolts on my d2 are missing, anyone know the the exact size/length that I need to replace them?
Old Aug 4, 2019 | 06:49 PM
cvhyatt's Avatar
Hey Twin6
Did you by chance happen to document which bolts went where? I did not document before I took out my engine. :-( Noob mistake.
Old Aug 4, 2019 | 07:32 PM
losinov's Avatar
Anyone recall which two bolts hold the two plastic or metal brackets that are attached to the transmission. I think the brackets hold the brake lines?
ahab
Mar 17, 2019 06:05 PM
abran
Dec 5, 2013 12:08 PM
0304Disco
Oct 15, 2012 05:16 PM
MrFlea1
Jan 25, 2012 10:58 AM
Bryan H
Jul 25, 2010 07:15 AM
