Can't separate bellhousing
Old Mar 17, 2019 | 04:17 PM
ahab's Avatar
Default Can't separate bellhousing
Is there a trick to this? AB video says "it usually pops off" with some yanking on the spreader bar... The RAVE doesn't give much info either.
I have the 4 torque converter bolts out, and all 12 bellhousing bolts. Engine mounts and exhaust manifolds are out of the truck. Ignoring any harness issues which might prevent me from getting the engine actually out (there aren't any), what am I missing about simply getting the bellhousing off the back of the engine? I tried prying through the small square access hole at the very bottom of the bellhousing but it just bent the screwdriver. If there another spot that's useful in helping to split the engine from the transmission?
Old Mar 17, 2019 | 04:59 PM
Jeff Blake's Avatar
Should be two more bolts buddy!
Old Mar 17, 2019 | 05:03 PM
ahab's Avatar
Excellent insight. It sure feels like there are two more bolts. Rave says remove 12, AB video says remove 12. WTF?
Old Mar 17, 2019 | 05:04 PM
Jeff Blake's Avatar
rave says remove 12, then later remove the last two
Old Mar 17, 2019 | 05:14 PM
ahab's Avatar
Yep, two more for sure. Thanks Jeff.
Old Mar 17, 2019 | 05:48 PM
Good catch Jeff
Old Mar 17, 2019 | 06:05 PM
ahab's Avatar
Amen to that. Thanks again. Much appreciated
twin6
Aug 4, 2019 07:32 PM
cozman
May 31, 2015 06:39 PM
TripleThreat
Mar 12, 2013 03:23 PM
Bryan H
Jul 25, 2010 07:15 AM
rambo
Jan 6, 2009 08:33 PM
