Here she is 1999 Discovery
Old Feb 28, 2016 | 09:31 PM
twhit2016's Avatar
Originally Posted by thesoundguru
You said you found the transmission check plug in the cup holder. Did you check the trans level. This isn't just a oh it's good check. You need to cycle through each gear and for each gear add fluid. If you have not done this you have no info to tell if the truck has fluid in the trans. this is the place to start. if you have done this and have a full level then we can talk more advanced diagnosis.
First thing is the plug I found was not the transmission plug. I replaced tranny filter, and topped off with fluid and cycled the gears and same issue. Did throw a "P0722" code which is why I have torque converter on the mind.
Old Feb 28, 2016 | 09:33 PM
twhit2016's Avatar
Originally Posted by Extinct
Are you sure the trans is full of fluid? If it will move in reverse but not forward it is likely not a torque converter issue, more likely a trans solenoid issue, or possibly a front clutch. Where are you located?
Northeast Arkansas. It threw a "P0722" code which is why is said troque converter, I downloaded "THE MANUAL" crazy how long it is.
Old Mar 1, 2016 | 05:09 PM
twhit2016's Avatar
So decided I will go with the transmission speed sensor first and see if that solves my problem. Hopefully it does otherwise I will be dropping the transmission.
AdrenalinPlease
Jan 22, 2014 10:00 AM
keoni004
Nov 4, 2012 11:44 PM
br0keit
May 6, 2012 12:30 AM
moneypit37
17
Jul 31, 2006 03:03 AM
Benhamtroll
Sep 11, 2005 09:46 PM
