Hey DiscoMike
Old Mar 26, 2009 | 09:46 AM
SafariDave's Avatar
4th Gear
Default Hey DiscoMike
So p1174 was fixed with the filter replacement (it's good to know that it has to do with either MAF or a clogged filter and not O2 sensors like p0174) I have run the diagnostic twice when I got the SES light again to make sure.
I replaced the CVS (vent valve) with a working used one from Paul Grant, but the p0446 came back, maybe his CVS is no good. I'm going to replace it again and send it back to Paul. I am wondering what else can give you a p0446. Some have had specific codes and they have replaced the part, to no fix, then they have either replaced a Gas Cap or Purge valve and the code went away, but p0446 is supposed to be a CVS. I think maybe the outlet that you connect the CVS unit harness into could be bad. Any suggestions Mike?
Thanks, Dave
Old Mar 26, 2009 | 03:39 PM
the 446 is an electrical issue with the CVS, not necessarily the vent itself.
Old Mar 26, 2009 | 07:31 PM
SafariDave's Avatar
4th Gear
Thanks I'll have the electrical checked &
David
Sabotage
May 28, 2013 05:17 PM
Hox
Jun 9, 2011 05:42 PM
bgfnbr
Feb 10, 2011 01:50 AM
Second2None
Apr 24, 2010 04:46 PM
DiscoveyII Driver
Jun 5, 2007 07:35 AM
