Hey guys I have a problem!
RE: Hey guys I have a problem!
OMG, whatever you do, don't drive your vehicle until you are sure the oil level is up to the proper level. You need to reach behind the cornering lamps up by the grille and there is a spring wire (circular wire about the diam of a quarter) and pull that to remove lamp. Then remove the light socket andfill with Land Rover fluid up to (but not over) the light socket hole. Do the same for the other side. I switched to synthetic and my fuel economy jumped 20%!
Headlights stop working/ 1999 Disco
My headlights worked fine enorute to work, when i turned them back on later only my secondary light in my headlight came on. I tried the highbeams and they worked but once released they cut right off. No click heard when i try to use the high beams. Frind said some type off relay in the steering column broken. What do u think?[&:]
