Hey guys I have a problem!
Old Mar 22, 2008 | 09:55 PM
BADBUZzZzZz's Avatar
Default Hey guys I have a problem!
I think my blinker oil is low how do I ckeck that?
Old Mar 22, 2008 | 10:08 PM
Mark G's Avatar
Default RE: Hey guys I have a problem!
OMG, whatever you do, don't drive your vehicle until you are sure the oil level is up to the proper level. You need to reach behind the cornering lamps up by the grille and there is a spring wire (circular wire about the diam of a quarter) and pull that to remove lamp. Then remove the light socket andfill with Land Rover fluid up to (but not over) the light socket hole. Do the same for the other side. I switched to synthetic and my fuel economy jumped 20%!
Old Mar 22, 2008 | 10:12 PM
LOL I will get on it thanks
Old Mar 22, 2008 | 10:38 PM
Glock23's Avatar
Default Headlights stop working/ 1999 Disco
My headlights worked fine enorute to work, when i turned them back on later only my secondary light in my headlight came on. I tried the highbeams and they worked but once released they cut right off. No click heard when i try to use the high beams. Frind said some type off relay in the steering column broken. What do u think?[&:]
Old Mar 23, 2008 | 08:26 AM
ORIGINAL: BADBUZzZzZz
Is this supposed to be funny?
Old Mar 23, 2008 | 09:22 AM
Why yes, yes it is.
Does anybody know where I can get new muffler bearings for my '97?
Sabotage
May 28, 2013 05:17 PM
Hox
Jun 9, 2011 05:42 PM
bgfnbr
Feb 10, 2011 01:50 AM
Second2None
Apr 24, 2010 04:46 PM
lowridersvt
Nov 14, 2004 01:55 PM
