HG vs liner
Old Oct 4, 2009 | 06:58 PM
Dexlen's Avatar
Default HG vs liner
How can you tell the difference between a HG failure and a slipped liner?
Just got a truck with a "blown motor" and trying to figure out if I'm going to need a new block.
Thanks.
Old Oct 4, 2009 | 07:23 PM
Eurotrash's Avatar
Remove Heads.
Old Oct 5, 2009 | 09:16 AM
Why guess, as mentioned, pull the engine down and see.
Old Oct 5, 2009 | 12:58 PM
AK Rover's Avatar
Whether it's head gaskets or a slipped liner the heads have to come off to know for sure and repair. If you do have a slipped liner a machine shop can reline the cylinder for about $800 per cylinder.
What symptoms are you getting from the blown engine? Will it run at all? Usually the engine will continue to run even with blown head gaskets or slipped liner it will just run poorly and use a large amount of coolant.
pinba1173
Appearance & Camping Set Ups
22
Jul 27, 2009 07:33 AM
scottma
Dec 26, 2008 10:49 AM
chrisusvi
Sep 22, 2007 07:37 PM
jkeving
Mar 8, 2007 03:28 PM
TOAD
Feb 6, 2007 09:07 AM
