Hi-Lift Jack....how big is yours?
Old Mar 14, 2014 | 09:35 AM
ralphobell's Avatar
Default Hi-Lift Jack....how big is yours?
What size Hi-Lift Jack are you using?
48" or 60" ?
Would you say the 48" is sufficient for the job or should I get the 60"?
Old Mar 14, 2014 | 09:57 AM
dusty1's Avatar
I go with 48 (had a couple laying around) and have never needed a 60. but I am going to be really pizzed if I need one and do not have it. If I needed to buy a new, it would be 60".
Old Mar 14, 2014 | 10:09 AM
ZGPhoto's Avatar
If I bought a new one, it'd be a 60, but for now it's a 48.
Old Mar 15, 2014 | 01:28 PM
Dane!'s Avatar
X2, i have a 48. But when I fit a long travel suspension up it'll be useless.
Old Mar 15, 2014 | 06:56 PM
antichrist's Avatar
Not if you use a ratchet strap or the like to keep the axle from dropping.
Old Mar 20, 2014 | 09:17 AM
Chrisinhouston's Avatar
I got the Smittybilt one which is 54 inches. Very similar to a Hi-Lift in most ways. I have it mounted on the spare tire swing out carrier. I finally got to use it last September when I blew a tire on the trail and had to do a tire swap. I used my ARB front bumper as a lift point but I do notice I have a very slight bow to it now. In hindsight maybe I should have used the wheel hook accessory and lifted it high enough to get my OEM jack under the front axle as I would not have had to go as high.
Old Mar 20, 2014 | 01:39 PM
Dane!'s Avatar
Good idea... very good idea.
Old Mar 20, 2014 | 02:22 PM
coors's Avatar
48"
Lifting the front is easy with the ARB but the back is a pain. To lift up the rear I have to insert a hitch extender into the receiver (I have one for my Thule "Mtn Bike" Carrier) then insert the Hi-lift into the extender.
yloDiscoII
ROAMING WITH FRIENDS
Feb 11, 2012 02:29 PM
llPANCHOll
Jul 26, 2009 10:40 PM
Street Wolf
Nov 20, 2008 01:13 PM
jigray3
Nov 13, 2007 04:27 PM
KwickSilverSF
Dec 5, 2006 10:39 AM
