Hi lift jack mount/ Tire ?
Old Aug 31, 2011 | 09:28 PM
bsnapp818's Avatar
Default Tire Size and hi-lift mounting question
Hey guys, me again. My OEM jack has taken a poop on me and I'm thinking I may just get me a Hi lift jack. I dont have a roof rack, or heavy duty front bumper. Can this be mounted to the spare tire? if so are there any brackets I need to buy or modifications that need to be made?
Also I have come across the Falken Rocky Mountain ATS in a size of 265/65/18. Someone said these should fit without a lift. What do you think?
Old Sep 1, 2011 | 12:41 AM
yloDiscoII's Avatar
The Hi-Lift jack can be mounted on the spare tire, but it's heavy and can really add strain to the already crappy door hinges....but sure does look damn cool
Here's a write up someone did...https://landroverforums.com/forum/di...45-28-a-36063/
265/65's should squeeze in, but it'll be close and you might get a little rubbing off road.
Old Sep 1, 2011 | 06:33 AM
hilltoppersx's Avatar
the hi-lift isn't very useful with a stock truck. you would have to get the lift-mate which is an accessory they sell that hooks into your rim and allows you to jack from there. But if you have a flat then you would still need to jack the truck up and then put a jack stand under the truck to change the tire. it's just too much to carry for a stock truck i would suggest getting another bottle jack unless you are thinking about getting sliders and off road front and rear bumpers that you can jack from.
Old Sep 1, 2011 | 09:14 AM
photocrimes's Avatar
I use a hitch mount. Jack bolts to it and then slides into the 2" receiver.
Old Sep 1, 2011 | 09:23 AM
I ran one on my spare along with a 265 tire for 7 years or more with no hinge damage.
As mentioned, this jack won't help while you have factory bumpers.
Attached Thumbnails Hi lift jack mount/ Tire ?-dscf0001_2.jpg
Old Sep 1, 2011 | 09:48 AM
how do you jack the front of the truck?
Old Sep 1, 2011 | 10:19 AM
Lol, its just to carry it. It's held on with a couple wing nuts. I'll post a pick when I get a chance.
Old Sep 1, 2011 | 01:34 PM
Tbras104's Avatar
5th Gear
I run a 265/65/18 with radius arm rub when turned to full lock, even with a 2" lift. I am adding hubcentric wheel spacers to see if I can avoid adjusting the steer stops and increasing my turning radius.
Old Sep 1, 2011 | 05:59 PM
Ok, mounted it quick and snapped a pick while I was putting in a new window motor and regulator. LOL, it's a labor of love
Hi lift jack mount/ Tire ?-jackmount.jpg
PS. I removed the rear step. I never liked that thing anyway. It was only held on by 2 bolts and came off as a assembly. It's the only thing on this truck that rusted, so I might work on restoring it and having it powder coated while it's off.
Old Sep 1, 2011 | 08:24 PM
there goes your approach angle. i would rip that thing off the first hour on the trail
