HID bulbs
Old Dec 7, 2009 | 09:51 PM
Classklown90's Avatar
Default HID bulbs
If i want to put HID bulbs in my 96 discovery do i need to buy an entire headlight or can the bulbs be switched out. thanks for the help
Old Dec 7, 2009 | 10:09 PM
AK Rover's Avatar
You can simply install a H4 HID conversion kit your original headlight housing. I have heard that the D2 headlights give a better beam pattern than the D1 but I never had any problems with mine.
Old Dec 7, 2009 | 10:49 PM
ok cool so a pepboys bulb set for example would just fit right in? anyone know the bulb size for the headlights as well as the fog lights?
Old Dec 7, 2009 | 10:54 PM
oysterhead's Avatar
will HIDs really be much different from set of Phillips bulbs?
Old Dec 8, 2009 | 07:17 AM
antichrist's Avatar
If you want to remain legal, the only way to do it is replace the entire housing. Installing HID bulbs in housings not made for HID violates federal regulations.
Old Dec 8, 2009 | 08:45 AM
hilltoppersx's Avatar
no. doesnt work like that. you need to get an HID conversion kit with includes a ballast that would have to be placed in the engine compartment. but as stated above the beam pattern is going to be a mess because your halogen housing is not built for the beam pattern of an HID bulb. so you will blind oncoming drivers. if you want to do it correct you can install headlights from an 03 or an 04 with minor work they will fit.
Old Dec 8, 2009 | 09:17 AM
JoMar's Avatar
I was told in no uncertain terms that I was a moron for putting HID in my '03 because the halogens somehow bend light differently than the HID bulbs. So I took them out. Even though there is a defined line where the light did not go above, including example photos and videos I was told I was wrong. So, my advice is to not bother with them.
If you want to see what HID's look like in an 03 - 15 feet from a garage door here is my video:
[youtube]http://www.youtube.com/watch?v=WYdCXp1R0wI[/youtube]
Photos of HID with dirty cellphone lens:
I took out the main lights and left in the foglights. They are fantastic.
I have a complete writeup on how to install these. If you are interested PM me and I will send it to you.
Old Dec 8, 2009 | 05:55 PM
Cant watch that video, it is private.
Old Dec 8, 2009 | 07:30 PM
antichrist's Avatar
Doesn't matter, he only showed the lights out to 15', which is nowhere near real world usage.
Old Dec 8, 2009 | 07:35 PM
15' is alittle short.
A video driving down the highway at night would be better.
But as already stated, HID kits are illegal.
