High Idle?
Old Oct 31, 2008 | 07:40 AM
pit_ownr's Avatar
Default High Idle?
I looked in my owners manuel and it says that my d1 should idle around 750 rpm's. Mine idles at 1200. It says it is not adjustable in the haynes manuel. is there any way to correct this or is there really anything wrong?
Old Oct 31, 2008 | 10:55 AM
Default RE: High Idle?
You should check for a vacuum leak, then clean the t/body and the IAC. Between those 3, one is causing your idle to be running high.
Old Oct 31, 2008 | 03:57 PM
IAC= Idle Air Control, it is a little valve on the throttle body, when it gets dirty is can cause all kinds of trouble, remove it and clean it with a spray can of carb cleaner.
Here is what it looks like.
http://www.roverparts.com/Parts/ERR5199.cfm
Old Nov 1, 2008 | 07:45 AM
pit_ownr's Avatar
how small is it.
Old Nov 1, 2008 | 08:01 AM
pit_ownr's Avatar
I am feeling like a total idiot. Does anyone have a picture of its location?
wick_60010
Nov 22, 2017 04:25 AM
omarica7
Mar 11, 2014 08:12 AM
rravenn13
Jul 19, 2007 04:40 PM
disco boy
Sep 18, 2006 10:30 AM
Brad S1
Jul 7, 2006 02:13 AM
