High Idle at Startup
Well my disco has not been driven in a few days, I go to start it and it goes up to 1800 rpm. it slowly starts to drop over a minute then at 1200 rpm it drops to normal idle. This has a brand new stepper motor and new ecu. I had this issue before but it stayed at 2000 rpm and ran like crap. So does this happen to anyone else? The throttle body is clean and so is the stepper motor and the hole.
Once at a normal idle it stays that way. I have noticed over the past couple of weeks that when you sometimes start it it will go high but immediately drop down (when cold). Seems that it is getting worse slowly.
oh yeah, land rover did it, the gems system had to be programmed for the vehicle. they set the base idle and installed a land rover stepper motor. spike, i dont know if you remember, i tried the jeep 4.0 stepper motor, then bough a third party one for it. it still idled high and then i took it to rover with a new(used) ecu. they reprogrammed it, installed a land rover stepper motor and programmed that, and i was good to go after $600. the issues i had the first time were way worse than this, the high idle this time just has me worried that I am going to have a repeat performance.
