High Idle Temps
Old Dec 13, 2014 | 11:43 AM
coors's Avatar
Default High Idle Temps
I normally would not start a new "coolant temp" thread, but I'm stumped and need some direction.
History:
I recently replaced head gaskets, BP Utah radiator, BP Utah water pump (brass impeller), but kept my ~year old Grey LR warm weather stat.
Issues:
My idle temps spike to 203 and drop to 201 - 202. I feel they should be around ~197 max (that's what I remember seeing on Ultragauge pre-head gasket replacement).
Cruising around town its fine, I'm at 190-194. Highway speed reads 188.6 - 190, consistently.
What do you think is causing these higher 'unstable' idle temps? I'm certain all the air is out of the system. Three days of obsessing over 'air in the system'. I'm fairly certain its bled out.
Old Dec 13, 2014 | 01:09 PM
dusty1's Avatar
Numbers look like air flow.. Fan clutch working fine?
If you raise rpms at idle does it drop quickly from the heightened flow? You could have busted some junk loose.
Are all the pulleys in good shape? Drag from a going out bearing could do it too
Old Dec 13, 2014 | 01:13 PM
Richard Moss's Avatar
Mine was getting warm at idle until I replaced the fan clutch. Now it can st there all day at desert temperatures and the temp gauge is rock steady.
Old Dec 13, 2014 | 01:14 PM
dusty1's Avatar
^^ Heisenberg ^^
Old Dec 13, 2014 | 04:48 PM
coors's Avatar
If I slightly raise the idle, the temps instantly drop.
Pulleys spin freely, I cleaned and re-packed during reassembly.
Fan clutch is what I was leaning towards. But I did the spin test at operating temp, the fan spun maybe a 1/4 to 3/8 of a turn. I thought that was normal, no?
Old Dec 16, 2014 | 04:29 PM
coors's Avatar
I had an interesting "discovery" today. If I get the A/C condenser fan to run my temps drop to 194.0. So, I'm thinking it's an air flow problem, like Dusty pointed out, but it seems the viscous fan is cranking some pretty darn good air without the help of the condenser fan. Hmm?
Should I just order a new clutch and be done with it?
Old Dec 17, 2014 | 09:05 AM
I would be prepared to bet that the clutch is weak and although the fan is turning, it's not turning fast enough.
wick_60010
Nov 22, 2017 04:25 AM
dparham
Apr 17, 2015 02:54 PM
dparham
Apr 14, 2015 08:44 AM
johnnyjohnny
Feb 23, 2014 08:55 AM
zombiedisco
Jul 18, 2013 05:20 PM
