High performance heads, just $62,000
Old Feb 14, 2015 | 10:46 AM
Broken08's Avatar
Default High performance heads, just $62,000
Check this out:
Performance V8 Cylinder Head Patterns suit Rover V8, Originally designed by Torque Developments U.K. these are the heads referred to in David Hardcastles Book "Tuning Rover V8 Engines" The design has been further modified and refined and the astute purchaser will see the value in having these heads manufactured in China or Korea to sell world wide. See separate listing for Performance Plenum and Throttle Body to suit the Series II 'Thor' Motor. enquiries to Tim +613 9436 1563
EBAY LISTING
Are these heads available anywhere? Anyone want to buy this and make me some? Is anyone using these heads?
Old Feb 14, 2015 | 11:41 AM
dusty1's Avatar
Not even if it were gold
Old Feb 14, 2015 | 01:27 PM
OffroadFrance's Avatar
Jeez, they have to be something very, very special even if they were gold you can buy a whole new race v8 for that money
Old Feb 14, 2015 | 01:54 PM
Broken08's Avatar
you didn't read it: this is for the production rights to the heads and the technical drawings.
As a side comment: where can I buy these so called "race heads"? Dusty has informed me i may be in for a head service soon, so I may as well put on some rockin heads.
Old Feb 14, 2015 | 02:05 PM
I believe Turners do gas flowed heads for the Rover V8's but there are others. If you want to 'zomp' up the performance you need to think about the bottom end, cams and enhanced oil pressure/flow and maybe upping the compression ratio a bit. As you probably already know there are many aspects to tuning and unless you culminate with the engine on a dyno you never know what's better or even worse and can waste lots of dosh just tampering with bits of the puzzle.
My doc keeps telling me I need my head servicing
dusty1's Avatar
you are still a maybe on head gasket
I have a build thread to lend info as to how I opened up my heads
340 heads = upgraded swap
Old Feb 14, 2015 | 02:13 PM
Broken08's Avatar
I will search and learn. More than anything I want strength and reliability. And if I can flow a bit more at my high altitude, Yay.
Old Feb 14, 2015 | 02:21 PM
dusty1's Avatar
just now got my heads from machine shop. I will be updating with more tech info on what I did. but a lot of the info and research came from same source as those heads.
though I wanted some reliability so not over the top....most of my upgrades would only be considered stage 3 ..... not a race rv8
Old Feb 14, 2015 | 04:38 PM
Broken08's Avatar
I will keep my eyes open for your info. I want to have some hardcore heads ready when my gasket goes
Old Feb 14, 2015 | 06:33 PM
drowssap's Avatar
64k is a bargin, seeing everyone with copy of that dam book thinks its worth $300.00
