High pitch noise 65-80 mph
Old 01-22-2017, 03:05 PM
adolfojbonilla's Avatar
Originally Posted by Friday Night Disco
I will reply later today with what I actually used for the rear diff, as I plan on draining it today. Also keep in mind you will need something to catch the oil as it drains. I use a small little bucket and dump the oil into a larger container that I transport to the local oil recycler
...thanks FRIDAY NIGHT DISCO! ...will be looking for that feedback later in the day, as per "something" to catch the draining oil, no worries, I have my oil drain pan from when I change the engine oil. ;-]#
  #22
Old 01-22-2017, 03:08 PM
Friday Night Disco's Avatar
Just drained the rear diff, took maybe 5 minutes
you will need a 1/2" socket wrench and 21mm socket
The 1/2" wrench is needed to remove the drain, the socket wrench fits right into the plug. I used a couple taps with a mallet to break it free.
The 21mm socket in needed to remove the oil level plug, be careful when taking this one on and off as there is rubber seal behind it.
  #23
Old 01-22-2017, 03:15 PM
High pitch noise 65-80 mph .................... it's really a 767 taking off from JFK
Seriously, it sounds like extremely dry UJ's in the driveshafts, possibly the cardan, which need greasing asap to avert a potential disaster.
  #24
Old 01-22-2017, 03:21 PM
...great thanks for the info; so you're not replacing that O-Ring, but reusing it? I knew it was there, but it would be good to have one or two on hand just in case, gotta find the right size of it as well. ;-]#
  #25
Old 01-22-2017, 03:26 PM
...in my case would be from FLL, but the comparison is on point! ...again, mechanic went underneath and confirmed all "looked" good, and that the grease job also seem to had been done thoroughly, and when he heard the thing taking off, he immediately pointed out to be the "differencial/front axel"... so I'll drain and refill to see if it solves it... I'll have the tires checked, maybe rebalanced to see if slight vibes goes away. Thanks for your feedback OFFROADFRANCE.
  #26
Old 01-22-2017, 03:30 PM
depending on the quality, I may reuse it but, do what ever you feel comfortable doing.
  #27
Old 01-22-2017, 03:41 PM
...I hear you! ;-]#
maing74
08-26-2011 10:07 PM
tibyABv6
02-23-2011 08:24 PM
mrjlyr
01-16-2010 04:00 PM
EDCOL
03-28-2009 05:18 PM
socalrover
02-09-2007 08:09 PM
Quick Reply: High pitch noise 65-80 mph
