High Temp's / No Fan (or fun!)...
Old Feb 10, 2014 | 01:14 PM
jamestfl's Avatar
Default High Temp's / No Fan (or fun!)...
so I've been working on bleeding the cooling system, and only this weekend did I notice the suggestions on jacking the front end up while doing it, what a difference that makes! but I still have some sloshing, so I'll try bleeding with jacked front end a couple of more times. ok, so it's gotten a bit warmer down here in Flatistan (Florida) and I have started using the a/c. I have never seen/heard the little aux fan move or make a peep at any point and with the a/c on, the temps like to ride at 210+. having thoroughly confused myself by reading a number of posts on the aux fan, etc., I'm a bit confused. Is / are there fuses and or relays that must be checked? who is the guy for replacement fans if that turns out to be the problem? sorry if this is a bit incoherent, rough weekend with a colicky 2 m/o little angel. thanks guys...
Old Feb 10, 2014 | 03:46 PM
dusty1's Avatar
did you look with the ac on? otherwise 212 is the kick on, with other factors.
and gripe water does wonders or a colicky baby
Old Feb 10, 2014 | 03:49 PM
Jared9220's Avatar
I just had to drain and fill the system this weekend and I noticed a few things that may help.
I jacked up the front end a bit, lifted the tank up high, unscrewed the bleed screw and started filling. While filling the tank I noticed it wasn't taking in the normal amount of coolant that it should and no coolant was coming out of the bleed hole when the tank was full.
I started squeezing all the different hoses until I found the one that made the most bubbles in the tank. I noticed that after pumping the hose a few times it took down a ton of coolant and started coming out of the bleed hole. I kept filling the tank allowing a lot of coolant to come out and then put the bleed screw back in.
I filled up the tank and then pumped on all the different hoses again until almost no bubbles came up in the tank. Then I removed the bleed screw all the way again and kept filling the tank as it poured out. I tightened the screw one last time and put the tank back in place.
Fill the tank over the fill line a bit and start the car on full heat and let it warm all the way up in the drive way then go for a good drive until the heater really starts warming up (10-15 minutes) .
Let the car sit and completely cool over night and top up the tank if it's low.
Old Feb 10, 2014 | 03:53 PM
Jared9220's Avatar
Try this thread I made to check you A/C fan motor. If you have questions please ask.
https://landroverforums.com/forum/di...n-motor-62983/
Make sure the temp outside is warm enough to make your fan come on when you turn on the A/C. The fan will not come on every time you turn on the A/C so be sure all the settings are right when testing it that way or you my misdiagnose a bad fan.
Old Feb 10, 2014 | 04:02 PM
jamestfl's Avatar
thanks guys. yeah, we use gripe water, but the poor thing still has bad crying. dr suggested rice cereal in the formula. checked the fan with the a/c on, no go. checked the #5 40 amp fuse in the box, looks good, whoops- which relay? have pumped all the hoses I can find- upper, lower, heater core in & out, manifold pre-warmer thingy hoses. when I had it jacked-up and was doing bleed (repeatedly) it would flow/gurgle bad/flow- did that about 1/2 dozen times, uses up a lot of coolant. no apparent leaks in any hoses or in the cabin. will try again in the am. thanks again.
Old Feb 10, 2014 | 04:05 PM
dusty1's Avatar
wait... uses coolant? as in level drops? no leaks?
Old Feb 10, 2014 | 04:08 PM
jamestfl's Avatar
during the bleed- pour coolant into bottle, flows and gurgles out of bleed hole. otherwise, no change in level in the overflow bottle during/after driving. sorry if that wasn't clear.
Old Feb 10, 2014 | 04:13 PM
dusty1's Avatar
gotcha and that rice cereal helped my girls,too.
Old Feb 10, 2014 | 04:20 PM
Jared9220's Avatar
Before you test the fan using the A/C, push the "ext" button and see what the temp outside is. If it's colder than 82F then the fan "will not" come on.
Old Feb 10, 2014 | 04:30 PM
captain203's Avatar
have you checked to see if the fan moves. Mine was seized and so was the replacement I got.
