Higher temps after new radiator, water pump etc
Old Mar 1, 2026 | 05:26 PM
Brando04's Avatar
Default Higher temps after new radiator, water pump etc
I just changed the radiator, water pump, fan and clutch, thermostat, expansion tank, all hoses and the temp sensor and now it’s running hotter than it used to? I bled the system twice and I’m still getting a reading of 210 before I shut the truck off..used to get 201.2 to 204 absolute hottest..I used a laser to measure the temperatures of the hoses and the upper are about 150 the lower radiator to thermostat hose is 110…I don’t get it? I’m going to try to bleed again but any advice? Thank you!!
2004 discovery 2 se
Old Mar 1, 2026 | 06:10 PM
Extinct's Avatar
Did you use an oem style thermostat? They have been know to be bad out of the box.
Old Mar 1, 2026 | 06:36 PM
redrover75's Avatar
It really makes a ton of sense to just get the inline thermostat. as finicky as these trucks are, it add an additional avenue to trouble shoot as well as manage temperatures more accurately. just return what you bought and get the inline. If you doing the work its crazy to not go the extra inch and make your life easier.
Old Mar 1, 2026 | 06:38 PM
Brando04's Avatar
I used the black 180 thermostat from lucky8
Old Mar 1, 2026 | 07:25 PM
Brando04's Avatar
Should I just put the old 180 thermostat that I know works?
Old Mar 1, 2026 | 07:58 PM
Best4x4's Avatar
Those non OEM Black 180F thermostats are not true 180F thermostats! You will need to look up inside of it for the temp rating, but only the black Britpart ones about 8 years ago were any good. After that they changed distributors and they're all the OEM temp range. The only OEM style thermostat to trust is the OEM Grey 180F, but I haven't seen an official OEM Grey 180F for sale in years. The Ebay units = in brown boxes with LR stickers = FAKE. It must be in a white box, and the body of the thermostat MUST be grey. Black, white, tan colored bodies = NOT 180F genuine OEM thermostats. Get the inline kit or verify the temp rating.
Old Mar 1, 2026 | 08:52 PM
Brando04's Avatar
is the PEL500110 thermostat from AB a good call? The soft spring one..I will do the inline in time but I need to get these temps under control in the mean time..thank you guys for the replies
Old Mar 1, 2026 | 10:01 PM
Extinct's Avatar
Suggest you read the inline thermostat thread at the top of the forum.
Old Mar 1, 2026 | 10:29 PM
Brando04's Avatar
I did..so if I have silicone hoses can I just cut the upper hoses to put the inline thermostat from intake to radiator
Old Mar 2, 2026 | 05:25 AM
Extinct's Avatar
Yes, you cut the tee out and put it there.
